Cisco IP SLA Packet Loss Configuration Help
Hello Community
Can someone please provide a link (or show me)  on how to configure ip sla to measure packet loss.
Please note, I'm aware that ip sla icmp-jitter will measure packet loss. Unfortunately, the router that I need to configure ip sla packet loss on does not have have that feature, so I have to configure it old skool, using reaction-configuration or reaction-trigger.
Your help will be greatly appreciated.
Cheers
Carlton
blau grana
Level 7
Level 7
Hello Carlton,
Here is older version of configuration icmp-jitter -> path jitter.
http://www.cisco.com/en/US/docs/ios/12_4/ip_sla/configuration/guide/hspthjit.html#wp1051321
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
blau grana
Level 7
Level 7
Hello Carlton,
Best Regards
Link is dead.  Do you recommend another?
Amafsha1
Level 2
Level 2
Mine does not support icmp-jitter either.  What did you end up using to measure packet loss in your sla configs?
