Cisco IR 1101 - DSL connection
aparna0123
Please give me a solution how do I configure.
Set up :    DSL broadband<---->WAN port [Cisco Router 1100 ISR ]LAN port<---------->Customer Switch
I have broadband IP details
ip address 108.1.1.89
gateway 108.1.1.90
subnet mask /29
How to i configure wan port and lan port so that customer can use 5 usable IPs
WAN interface should connect to broadband and be assigned a public IP.
LAN interface should pass the public subnet to the customer switch.
Kindly provide a solution how do i configure the at layer 3 so that customer can access the network.
Customer has shared Private IP , lets say 192.168.1.0/24 network
Also , please help me with any alternate solution , do i have to assign /29 subnet public IP at LAN end so that customer can use it. Or I can use NAT/PAT so that customer can use the IPs. ? Need help with config and optimum solution.
Hello
You can use PAT with a Nat pool to accommodate your multiple public ip range
Example:
Int dialer x
ip nat outside
int x/x
description LAN
ip nat inside
ip access-list standard 10
permit ip 192.168.1.0 0.0.0.0 any
ip nat pool  ISP 108.1.1.91 108.1.1.94 prefix-length 29
ip nat inside source list 10 pool ISP overload
ip route 0.0.0.0 0.0.0.0 dialer x 108.1.1.90
Kind Regards
Paul
shambhu.kumar
Hello aparna0123,
Need some clarity here,
Has service provide allocated /30 IP address for WAN ? If you are using copper 1GE WAN interface, What would be the point to point IP  at your end of WAN interface and service provider end ? Not sure are you using cellular interface or copper 1GE WAN interface?
you can configure NAT with share IP pool 192.168.1.0/24 and need to provide what is the  NAT outside interface IP to complete the configuration.
