Cisco Ironport
Cisco Ironport S370 is able to fetch only 1000 users from the AD, while testing. There are more than 5000 users in the AD. Is there a limiitation ?
5 Replies 5
Hi sridharmohanraj21,
As far as i know the license for Cisco Ironport is only for the license itself and not per user but i will check you need any additional license for this. what type of license do you currently have for the Cisco Ironport?
Ferdinand Guasque
fguasque@cisco.com
I have a different question.  Our problem is the Cisco IronPort Email Security Plug-In for Outlook keeps getting disabled because it is so slow.  I couldn't find a bug fix, any suggestions?
Thank you,
which version of the plug-in do you have installed (e.g.7.5.2) ?
Version 7.1.0.039
Thank you
