CISCO ISR 4331 low WAN Speed
sergeykaw0w
The provider delivers a speed 200 mbps, and the ISR 4331 delivers a maximum of 100 mbps.
sh run:
interface GigabitEthernet0/0/0
 ip address 123.456.789.149 255.255.255.252
 ip nat outside
 negotiation auto
 crypto map VPN
interface GigabitEthernet0/0/1
 ip address 192.168.3.249 255.255.255.0
 ip nat inside
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/1/0
 switchport access vlan 2
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface Cellular0/2/0
 no ip address
 shutdown
interface Cellular0/2/1
 no ip address
 shutdown
interface Service-Engine0/4/0
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
interface Vlan1
 no ip address
 shutdown
ip nat inside source list NAT interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 123.456.789.149
ip ssh version 2
ip access-list standard SSH
 permit 192.168.0.0 0.0.255.255
ip access-list extended NAT
 deny   ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
 permit ip 192.168.3.0 0.0.0.255 any
 permit ip 192.168.2.0 0.0.0.255 any
ip access-list extended VPN
 permit ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
 permit ip 192.168.3.0 0.0.0.255 192.168.12.0 0.0.0.255
 permit ip 192.168.3.0 0.0.0.255 192.168.15.0 0.0.0.255
 permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
 permit ip 192.168.2.0 0.0.0.255 192.168.12.0 0.0.0.255
 permit ip 192.168.2.0 0.0.0.255 192.168.15.0 0.0.0.255
 permit ip 192.168.3.0 0.0.0.255 192.168.13.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 logging synchronous
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 access-class SSH in
 logging synchronous
 login local
 transport input ssh
line vty 5 97
 access-class SSH in
 logging synchronous
 login local
 transport input ssh
end
sh int gi 0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
  Hardware is ISR4331-3x1GE, address is 501c.b07f.7e80 (bia 501c.b07f.7e80)
  Internet address is 123.456.789.0/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 2/255
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is auto, media type is RJ45
  output flow-control is on, input flow-control is on
  Last input 00:54:04, output 00:00:22, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 114512
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 11151000 bits/sec, 1067 packets/sec
  5 minute output rate 2433000 bits/sec, 574 packets/sec
     42894597 packets input, 49050095063 bytes, 0 no buffer
     Received 3697 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     24015266 packets output, 8710495611 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     4 lost carrier, 0 no carrier, 0 pause output
P.S. Sorry for my English :)
Well the throughput is the issue
If I understand correctly from the cisco page it should be the command
platform hardware throughput level 300000
Assuming the license you have supports that, if that doesnt work you might have to activate/register the license but i dont have any experience in that part
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/interface/command/ir-cr-book/ir-o1.html#wp3800310030
To change the maximum throughput level on the virtual router, use the platform hardware throughput level command in global configuration mode. To return the platform throughput level to the default value, use the no form of this command.
Cisco IOS XE Release 3.9S:
platform hardware throughput level { 10000 | 25000 | 50000 | eval-only }
Cisco IOS XE Release 3.10S and Later:
platform hardware throughput level MB { 10 | 100 | 1000 | 25 | 250 | 50 | 500 }
Syntax Description
10000
Sets the maximum throughput to 10,000 Kbps (10 Mbps).
25000
Sets the maximum throughput to 25,000 Kbps (25 Mbps).
50000
Sets the maximum throughput to 50,000 Kbps (50 Mbps).
eval-only
Specifies to use the maximum throughput for the evaluation license only.
Cisco IOS XE Release 3.10S:
Sets the maximum throughput to 10 Mbps.
100
Sets the maximum throughput to 100 Mbps.
1000
Sets the maximum throughput to 1 Gbps.
25
Sets the maximum throughput to 25 Mbps.
250
Sets the maximum throughput to 250 Mbps.
50
Sets the maximum throughput to 50 Mbps.
500
Sets the maximum throughput to 500 Mbps.
Command Default
The default maximum throughput level is determined by the installed base license.
Command Modes
Global configuration (config)
Command History
Release Modification
This command was introduced on the Cisco CSR 1000V Series Cloud Services Router.
Cisco IOS XE 3.10S
The command was updated to change the keywords to units in Mbps, and support for maximum throughput values of 100 Mbps, 250 Mbps, 500 Mbps, and 1 Gbps was added.
Usage Guidelines
The Cisco CSR 1000V requires the installation of base licenses that set the maximum throughput of the platform.
Depending on the configuration and the licenses installed, you may need to manually increase or decrease the maximum throughput level on the Cisco CSR 1000V. The maximum throughput on the router before the license is activated, or if the license is invalidated, is 2.5 Mbps. When you install the base subscription license and accept the EULA, the maximum throughput on the Cisco CSR 1000V will increase to the level allowed by the license.
You may need to manually change the maximum throughput level in the following cases:
  • If you are using an evaluation license. When the evaluation license is first installed, the maximum throughput is limited to 2.5 Mbps before the license is activated. You must accept the EULA and enter the platform hardware throughput levelcommand to increase the maximum throughput. When the 60-day evaluation license expires, the maximum throughput level reverts to 2.5 Mbps.
  • If you want to reduce the maximum throughput level from the maximum permitted by the installed licenses. For example, if you have the 50-Mbps license installed and you want to reduce the maximum throughput to 25 Mbps. You must enter the platform hardware throughput level command to reduce the maximum throughput.
  • If you previously changed the maximum throughput using the platform hardware throughput level command. When you enter the command, it becomes part of the configuration file. You must enter the command again to change the maximum throughput level.
When changing the maximum throughput level, you do not need to reboot the Cisco CSR 1000V for the change to take effect. If you try to increase the throughput level higher than what the installed license supports, you will receive an error message.
Examples
The following example changes the maximum throughput level to 500 Mbps:
Router(config)# platform hardware throughput level MB 500
The following example changes the maximum throughput level to the default level supported by the installed license:
Router(config)# no platform hardware throughput level
Related Commands
Command
Description
show platform hardware throughput level
Displays the current maximum throughput level for a virtual router.
8 Replies 8
HADES2001
The specifications also mention that the base throughput is 100 for the Cisco 4331.
You can upgrade it with a license up to 300.
For more on the specifications please see
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/datasheet-c78-732542.html
Do you have the extra license?
I think I have a extra license.
branch_vpn_ala#sh vers
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
branch_vpn_ala uptime is 2 days, 19 hours, 38 minutes
Uptime for this control processor is 2 days, 19 hours, 40 minutes
System returned to ROM by reload
System image file is "bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     FoundationSuiteK9     Permanent      FoundationSuiteK9
securityk9
appxk9
AdvUCSuiteK9          AdvUCSuiteK9          Permanent      AdvUCSuiteK9
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           None             None             appxk9
uck9             None             None             uck9
securityk9       None             None             securityk9
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4331/K9 (1RU) processor with 3696789K/6147K bytes of memory.
Processor board ID FLM2152V1HP
7 Gigabit Ethernet interfaces
2 Cellular interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
7057407K bytes of flash memory at bootflash:.
can you try the following command?
sh platform hardware throughput level
This should give the current throughput level
The command
show license feature
Should give a good overview of all licenses
The current throughput level is 100000 kb/s
branch_vpn_ala#sh license feature
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightT        oUse
appxk9                   yes          yes         no             yes      yes
uck9                     yes          yes         no             yes      yes
securityk9               yes          yes         no             yes      yes
ipbasek9                 no           no          no             yes      no
FoundationSuiteK9        yes          yes         no             yes      yes
AdvUCSuiteK9             yes          yes         no             yes      yes
cme-srst                 yes          yes         no             no       yes
hseck9                   yes          no          no             no       no
throughput               yes          yes         no             no       yes
internal_service         yes          no          no             no       no
Syntax Description
10000
25000
50000
eval-only
100
1000
25
250
50
500
Command Default
Command Modes
Command History
Cisco IOS XE 3.10S
Usage Guidelines
Examples
Related Commands
Command
Description
I think it is pretty sad that you have bandwidth limitations built into the software now. I understand licensing for software that performs duties a normal router wouldn't do, and paying for a license to run it in the router IOS.
But I am purchasing a high end router that should be able to go to several hundred mb without issues. You can get that from a Best Buy router. To limit bandwidth to 50 mb  <on the 4321> and have to buy a performance license for it to do 100 mb, but then, {oh, you really want it to do 100?}, because it is limited to 85 mb for ipsec, that is ANOTHER license to download and install. The router was purchased with advanced security already, which was also an extra cost. Having a router that doesn't fully function due to software limiting is just wrong and needs to be corrected.
BTW, a reason for the 85 Mbps IPSec performance limitation is due to US export laws.
Yes, a "Best Buy" router likely doesn't have similar license performance restrictions, and our free market allows you to buy one rather than a Cisco router. If enough buyers did that, I suspect Cisco would change its licensing policy.
TY!!!!!
