Cisco ISR 4351 - Is Wall Mounting Possible?
dnanne
Good morning,
We are planning to use a Cisco ISR 4351, but are limited in the space available in our rack.  I would like to ideally wall-mount this unit.  Is it possible to wall mount the 4351?  If not, what prevents it from being wall-mountable?
Thank you,
David
chrihussey
There shouldn't be an issue if you wall mount the router. The trick is to make sure the chassis has the screw holes in the proper place so that you can utilize the rack mount brackets for this purpose. If not, you'll have to figure out a way to properly secure the router. The below link references wall mounting other 4000 series model routers:
http://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/Install_Connect.html
Just make sure airflow and accessibility is not compromised.
Hope this helps.
