Cisco ISR 4431 lan issue
Hi all,
I am facing very strange problem in my setup. I have two routers (1 cisco 4431/k9, 1 cisco 2900) both are connected point to point via service provider and there is a lan behind the router both the side.
I have configured the default route on both the routers and static route for the lan.I am able to ping point to point routers but unable to ping lan.
Please find the attached diagram for the reference
post the full configurations of both routers. Can the LAN clients ping the WAN interface of their respective routers ?
balaji.bandi
as suggested post the config, and you failed results of ping.
If you do not have any block on FW, you can produce traceroute, will give where this is blocking.
BB
