Cisco ISR 4451-X HSRP group limit
Cannoo
We have 49 HSRP groups on one interface of our current routers and need to migrate to the 4451's, but the limit appears to be 25. Does anyone know if this is a hardware limit that won't be increased or if there is a possibility for a firmware upgrade to increase it? I have already upgraded them to the latest release and it's at 25.
Cannoo
Thank you to anyone who responded, but I have spoken to a Cisco support engineer now and it is indeed a hardware limit on the number of MAC addresses that can be stored. Only option would be an additional module for the switch that can support more addresses.
balaji.bandi
can you post show version (old and new device to understand the issue)
also post full logs you see on the new device.
BB
Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9-M), Version 15.4(3)M5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 09-Feb-16 00:34 by prod_rel_team
ROM: System Bootstrap, Version 15.1(1r)T4, RELEASE SOFTWARE (fc1)
 uptime is 20 weeks, 1 day, 16 hours, 35 minutes
System image file is "flash0:c3900e-universalk9-mz.SPA.154-3.M5.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE200/K9 with 754688K/293888K bytes of memory.
Processor board ID FCZ154620L9
4 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
256K bytes of non-volatile configuration memory.
255744K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Technology Package License Information for Module:'c3900e'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      securityk9           Permanent      securityk9
uc            None                 None           None
data          datak9               Permanent      datak9
NtwkEss       None                 None           None
CollabPro     None                 None           None
Old devices are 3925's and show version provided. Don't currently have access to the new routers today. I can grab this, but don't think it's needed for the issue?
The 4451' s are on version 16.12 (
isr4400-universalk9.16.12.04.SPA.bin
show standby capability from 4451's:
ISR4451-X/K9 * indicates hardware may support HSRP
Interface Type H Potential Max Groups per subin
Gi0/0/0 27 ISR4451-X-4x1GE * 25
Gi0/0/1 27 ISR4451-X-4x1GE * 25
Gi0/0/2 27 ISR4451-X-4x1GE * 25
Gi0/0/3 27 ISR4451-X-4x1GE * 25
GigabitEthernet0 27 RP management port * 4096
LIIN0 27 LIIN -
does that limit still apply with HSRP version 2 (with 1 being the default I think) ?
interface GigabitEthernet0/0
--> standby version 2
Cannoo
