Power Connection on Cisco C899G LTE
radiomean
Hi, I have just bought a Cisco C899G LTE, with the 4 pin square power plug. The router does not have a power brick with it - does anyone know what the pin-out is so I connect a temporary PSU?
Cheers, Bill
marce1000
 - https://www.cisco.com/c/en/us/td/docs/routers/access/800/hardware/installation/guide/800HIG.pdf
                                  Have a look atFigure 3-33
 M.
marce1000
 M.
Thanks! I have also found a manual for the IR829 which gave me the same information, plus 'ignition noise suppression'!
Cheers...
Edit 1 - the router is running now, so the pin out is certainly correct!
Edit 2 - pages 57 and 58 of the following document show the pinout...
https://www.cisco.com/c/en/us/td/docs/routers/access/800/829/hardware/install/guide/b_IR829-HIG.pdf
