08-22-2025 02:18 AM
I am preparing to deploy the Cisco ISR C1111-8P and 4P (ISR 1100 Series – 8 Ports Dual GE WAN Ethernet Router).
I have a few questions and would really appreciate your advice:
Any additional tips or experiences with this model would be very helpful.
Thank you in advance!
08-22-2025 02:22 AM
Check command available in your router
Use
Interface?
See what options you have
For PO L3 yes it support in ISR 1K
MHM
08-22-2025 02:30 AM
I am currently preparing to deploy the ISR C1111, but I don’t have the router on hand yet to test the commands myself.
08-22-2025 02:37 AM
Check all config you need in this guide
MHM
08-22-2025 02:51 AM
I have read through Cisco’s guide, but to be sure, I would like to ask if anyone who has deployed or is currently managing this model could log in and check whether it supports configuring interface VLAN and port-channel.
