Cisco ISR C1117
digi076
Hey guys,
We have a test lab in our office where we used to work with a Cisco 887va on a VDSL circuit.
Now we have a new setup with a Cisco ISRC1117-4PLTEEA on the same circuit.
The latter is using IOS-XE.
Everything works fine except for the voip phones. They cannot provision anymore. Showing "no service" on the display. They do receive a IP-address via DHCP. They connect to a Asterisk based PBX external.
So basicly the config is the same like it was on the 887va, but I have no idea why the phones are not registering anymore.
Anyone in the same boat on this? Suggestions much appreciated :)
Thank you.
johnd2310
Level 8
Level 8
Are you using firewall on the router? is there any port forwarding and is it same as 887?
John
**Please rate posts you find helpful**
hi John,
no the ZBF is not enabled, just ACLs which are the same as the 887 router.
There are no port forwardings..
