Cisco isr113 - flexvpn - issue while entering *$AnyConnectClient$*
Luca Pecchiari
i moved from C897 to ISR 113-8p
i created again the Ipsec - flexvpn profile but while i enter
crypto ikev2 profile AnyConnect-EAP
 match identity remote key-id *$AnyConnectClient$*
the reouter get only:
 match identity remote key-id **
and i get error on Cisco Any connect VPN.
with the debug:
Sep 22 21:46:34: IKEv2:(SESSION ID = 38,SA ID = 1):Searching policy based on peer's identity '*$AnyConnectClient$*' of type 'key ID'
Sep 22 21:46:34: IKEv2-ERROR:% IKEv2 profile not found
it is clear that *$AnyConnectClient$* cannot be found...
i run: c1100-universalk9.17.09.04.SPA.bin
Guys, do you have some ideas to enter the string proprely?
Thank you
Luca Pecchiari
find out:
i have to insert as:
match identity remote key-id *\$AnyConnectClient\$*
