cisco router 2621 cannot open "flash:
dwtdlt3000
rommon 2 > boot
device does not contain a valid magic number
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
rommon 3 > dir flash:
dir: cannot open device "flash:"
rommon 4 > dev
Devices in device table:
id name
flash: flash
rommon 5 > dev id
id name
flash: flash
rommon 6 > dev flash:
id name
flash: flash
rommon 7 > bootflash:
monitor: command "reload" not found
rommon 13 > reset
System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 2000 by cisco Systems, Inc.
C2600 platform with 32768 Kbytes of main memory
M02@rt37
Hello @dwtdlt3000,
You need to copy a valid image on C2621 again.
You can now recover the C2621 IOS image using one of the following ROM monitor commands *assuming you have a bin file as C2621 IOS*
--xmodem: Use your computer attached to console port has a terminal emulator that has xmodem capability.
https://community.cisco.com/t5/networking-blogs/firmware-image-recovery-upload-via-xmodem-rommon-console-serial/ba-p/4164855
--tftpdnld: use TFTP server directly connected to the Ethernet port.
https://community.cisco.com/t5/networking-knowledge-base/the-tftpdnld-rommon-command-recovery-procedure-fails-due-to/ta-p/3131356
Best regards
thank you, i will try this when i get a chance.
