Cisco Linksys E2000 has extremely weak wireless signal
degibox23
Hi, all.
For a few months now my Linskys e2000 wireless router has been sending a very weak signal. It's even weak when I'm sitting a mere 12 feet from it. And forget walking down the hall and into the other part of my apartment. Lots of 4G data being used on my phone that wasn't before.
Any suggestions on how to strengthen the signal? Thanks.
degibox23
devils_advocate
Level 7
Level 7
I am not familiar with this model of AP but can you check what the Transmit power is set to?
Have you changed anything on the configuration? Seems odd how it would suddenly have poor signal one day.
Few posts I found online:
http://tomatousb.org/forum/t-378011/e2000-tips-tricks-v-wireless-strength
http://www.linksysinfo.org/index.php?threads/asus-rt-n16-transmit-power.33078/#post-163118
http://sillydog.org/forum/suggestions-for-improving-signal-strength-t17508.php
May be worth trying the actual Linksys forum as this one tends to be more focused on enterprise Cisco products.
Leo Laohoo
Cisco palmed the Linksys brand to Belkin.  So I'd recommend contact Belkin for support.
