Upgrade Standalone ASR 1001
I'm trying to upgrade to an ASR 1001 but throws me the following error
Router#issu loadversion rp 0 file bootflash:asr1001-{rpaccess,rpios,rpcontrol}*03.16.01a.S.155-3.S1a-ext*.pkg bay 1 force
--- Starting local lock acquisition on R0 ---
Finished local lock acquisition on R0
--- Starting file path checking ---
Finished file path checking
--- Starting image file verification ---
Checking image file names
Locating image files and validating name syntax
Found asr1001-rpaccess.03.16.01a.S.155-3.S1a-ext.pkg
Found asr1001-rpios-universalk9.03.16.01a.S.155-3.S1a-ext.pkg
Found asr1001-rpcontrol.03.16.01a.S.155-3.S1a-ext.pkg
Verifying image file locations
FAILED: Installation of sub package over consolidated package not allowed
thanks!
Ganesh Hariharan
Have you gone through the below link for upgrading ASR IOS software.
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/asrswcfg/issu.html#wp1162196
Hope it helps..
-GI
Jasvir Singh
Hi Cristobal
Did you find the solution for this issue?
Leo Laohoo
If this is a "standalone" ASR then why bother using ISSU?  Copy the IOS into the "bootflash" and then change the boot variable string.  KISS.
