Cisco LoraWan Gateway does'nt start anymore
s-obereder
Hello there!
I got following problem: Two of my Cisco Lorawan Gateways won't start they are in a "Resetloop" (look cut out below). A Uboot-Reset doesn't help either. So the question i got is can i, or even better, how can i make them working again?
Thank you very much in advance for your help.
Regrads Simon
CONSOLE CUT-OUT:
Initialize DB-GP board topology
Device 6810 supports only 2 GbE ports: SGMII-2 @ lane5 disabled (setting USB3.0 H1 instead)
updateTopologySatR: TWSI Read of 'gpserdes1/2' failed
Device 6810 does not supports SerDes Lane #4: replaced topology entry with lane #5
Device 6810/20 supports only 2 SATA interfaces: SATA Port 3 @ lane3 disabled
board SerDes lanes topology details:
| Lane # | Speed| Type |
| 0 | 5 | PCIe0 |
| 1 | 3 | SATA0 |
| 2 | 3 | SATA1 |
| 5 | 5 | USB3 HOST1 |
PCIe, Idx 0: detected no link
High speed PHY - Ended Successfully
DDR4 Training Sequence - Ver TIP-0.21.(Sublib 0.5)0
DDR4 Training Sequence - Switching XBAR Window to FastPath Window
DDR Training Sequence - Start scrubbing
DDR Training Sequence - End scrubbing
DDR4 Training Sequence - Ended Successfully
Not detected suspend to RAM indication
BootROM: Image checksum verification PASSED
BootROM: Boot image signature verification PASSED
reset_count = 76
Saving Environment to SPI Flash...
Erasing SPI flash....Writing to SPI flash.....done
resetting ...
BootROM - 1.73
Booting from SPI flash, Secure mode
BootROM: RSA Public key verification PASSED
BootROM: CSK block signature verification PASSED
BootROM: Boot header signature verification PASSED
BootROM: Box ID verification PASSED
BootROM: JTAG is disabled
General initialization - Version: 1.0.0
AVS selection from EFUSE disabled (Skip reading EFUSE values)
Overriding default AVS value to: 0x23
mvSysEnvIsFlavourReduced: TWSI Read of 'flavor' failed
Detected Device ID 6810
High speed PHY - Version: 2.0
| 0 | 5 | PCIe0 |
| 1 | 3 | SATA0 |
| 2 | 3 | SATA1 |
reset_count = 77
resetting ...
BootROM - 1.73
Torbjørn
I would raise a TAC case for this. It doesn't seem like a configuration error to me
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
