cisco nat, dynamic ip from isp
Gergo Vadasz
Hi!
I think I understand the cisco NAT-PAT thing, but I try to manage this at my office with a 1841 router, and I don't know how to solve, that my ISP uses dynamic IP-s, and every 24 hours the public IP address is changing.
Must I change the router config every day to use NAT-PAT?
Thank you and sorry for the noob question!
Gergő from Hungary
cadet alain
No, just use the NAT overload feature like this:
ip nat inside source list 1 interface g0/0 overload
where int g0/0 is your external interface with the DHCP address.
Alain
cadet alain
Alain
Hi Alain!
Thank you for your reply. I forgot to mention, that my ISP needs a pppoe authentication. Does's this information change your answer? I need the replace the interface g0/0 to Dialer1?
Thank you!
Yes you're correct.
Alain
