Cisco NCS / host-routing !!% Resource temporarily unavaila:
Hi Partners!
I have a problem configuring forty-two BVI interfaces on Cisco NCS 55A1.
The problem began after configuration 30 of 42 BVI whit Anycast Routing (Host Routing) the other BVI interfaces automatically were rejected by the subsequent notification:
!!% Resource temporarily unavailable: Too many interfaces of this type
I don't find information related to the actual capacity of BVI with Host routing or something that brings me some information about it.
If some of you know how to deal with this I appreciate his comments!!
Greetings!
Log:
RP/0/RP0/CPU0:LOG-RTL-NCS1(config)#show configuration failed
Fri Feb 10 23:19:25.858 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
interface BVI576
 host-routing
!!% Resource temporarily unavaila: Too many interfaces of this type
interface BVI577
 host-routing
interface BVI578
 host-routing
interface BVI579
 host-routing
interface BVI580
 host-routing
interface BVI581
 host-routing
interface BVI582
 host-routing
interface BVI583
 host-routing
interface BVI584
 host-routing
interface BVI636
 host-routing
interface BVI693
 host-routing
interface BVI694
 host-routing
end
Mark Elsen
 - Try latest advisory release https://software.cisco.com/download/home/286322549/type/280805694/release/7.5.2 , if applicable , check if that can  help.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
