Static Route to OSPF redistribution - filtering issue using route-map
gorai.chandan
We are seeing an issue where route filtration is not working, when we are redistributing static routes to OSPF area0. We have some static NULL routes in our SW01-WAN, which we don't want to redistribute towards SW01-CORE, but it getting redistributed. The null routes should get filtered if there is implicit deny in the ACL and route-map. Can someone help me what is the issue with the configuration?
Config:
SW01-WAN (N7K vdc-1)
SW01-WAN# sh run | in route
ip route 10.194.0.0/17 Null0
ip route 10.194.128.0/17 Null0
router ospf 1
router-id 10.194.0.3
redistribute static route-map REDISTRIBUTE-STATIC-TO-OSPF
area 0.0.0.0 authentication message-digest
log-adjacency-changes
auto-cost reference-bandwidth 1000000
passive-interface default
SW01-WAN# show route-map REDISTRIBUTE-STATIC-TO-OSPF
route-map REDISTRIBUTE-STATIC-TO-OSPF, permit, sequence 10
Match clauses:
ip address (access-lists): REDISTRIBUTE-STATIC-TO-OSPF
Set clauses:
metric-type type-1
SW01-WAN# sh ip access-lists REDISTRIBUTE-STATIC-TO-OSPF
IP access list REDISTRIBUTE-STATIC-TO-OSPF
10 permit ip 10.194.224.0/24 any
20 permit ip 10.194.225.0/24 any
SW01-CORE (N7K vdc-2)
SW01-CORE# show ip route 10.194.0.0
IP Route Table for VRF "default"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
10.194.0.0/17, ubest/mbest: 2/0
*via 10.194.1.30, Eth5/1, [110/120], 3y19w, ospf-1, type-1
*via 10.194.1.34, Eth2/13/3, [110/120], 3y19w, ospf-1, type-1
SW01-CORE# show ip route 10.194.128.0
10.194.128.0/17, ubest/mbest: 2/0
Your config is correct from my view only use prefix list instead of acl.
Richard Burts
This would appear to be fairly straightforward. Your static routes are for /17 but your acl is checking for /24.
Rick
Hello
You could try the following:
ip route 10.194.0.0/17 Null0 tag 1
ip route 10.194.128.0/17 Null0 tag1
route-map REDISTRIBUTE-STATIC-TO-OSPF deny 10
match tag 1
route-map  REDISTRIBUTE-STATIC-TO-OSPF permit 99
Kind Regards
Paul
gorai.chandan
Thanks all for the help and suggestion.
It seems the issue is related to the below bug.
Cisco Bug: CSCtt04685
NXOS: routing redistribution route-map with ACL will allow any prefix
