Cisco Packet Tracer 3xRouter routing problem
reimpsel
Hello guys
I ran into problem testing the Static routing with 3x routers.
For some reason when i build the setup with 3 routers the third network (PC2) is unable to ping even its own network gateway.
What i am missing here? or is it some kind of bug?
The routing works fine between R1 and R2 networks.
project file added in attachment
2 Accepted Solutions
Blue_Bird
Hello reimpsel,
Ip address is incorrect..!  on 3rd router. You given 192.163.30.1, it should be 192.168.30.1
change to correct ip, it works..!
Best regards
******* If This Helps, Please Rate *******
Hello @reimpsel
 Your router configuration is wrong. You used 192.163.30.1 and should be 192.168.30.1
Blue_Bird
Hello reimpsel,
Best regards
ohh boy... such an embarrassing moment. Thank you for noticing!
Hello @reimpsel
