Cisco Privilege Question :)
Iluvnetwork
R1(config) username ccna privilege 0 secret ccna
R1(config) username ccie privilege 15 secret ccie
line con 0
login local
After that, I logged in using ccna username and username ccna's privilege level was 15 :(
Can anyone tell me how to properly configure privilege and what I am missing? I want ccna to access only show command and ccie to all commands.
remove the line below from your configuration:
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
8 Replies 8
add the lines below to you configuration:
aaa new-model
aaa authentication login default local
aaa authorization exec default local
Still ccna has 15 privilege level...
line vty 0 4
login authentication default
Not working...
Current configuration : 805 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
aaa new-model
ip cef
no ipv6 cef
username ccie privilege 15 secret 5 $1$mERr$RyxJPPKgNUtlrgAujv76v.
username ccna privilege 0 secret 5 $1$mERr$Bok4KDfVutXOJolNq009M/
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
end
Username: ccna
Password:
Router>en
% No password set.
Router>en
Password:
Router#show pri
Current privilege level is 15
odd. What are you testing this with, real devices, or simulators such as Packet Tracer or GNS3 ? What is the source of your TELNET, that is, from where are you trying to access the router ?
I used both Packet Tracer 7.1 and GNS3. Router 1 --- Router 2. I am teleting to 1.1.1.2 from 1.1.1.1
Thank you :) Finally Working!
