Cisco - Route-map vs. access-list
bobqiu262
Could anyone explain the differece between Route-map and access-list.
In which case I should use Route-map?
satish_zanjurne
Level 4
Level 4
Access-list are just ways to allows or deny hosts based on few parameter like Destination,Source IP address, port, protocols etc.
Whereas , Route-Maps are the way to Policy Based Routing in Cisco IOS.
Route-Maps are like software programming,
1.you can use to manipulate the whether routes can be installed in the routing table or not ,
2.to what extent the metric of route needs to changed,
3.In BGP to change/set the attributes of routes.
Many of the times Route-Maps make use of access-lists
e.g
access-list 10 permit 192.168.1.0 0.0.0.255
route-map test-route-map
match ip address 10
In above example route-map test-route-map used the access-list 10 to match the IP Addresses.
HTH...rate if helpful...
Is there any guide about how to use route-maps?
I still not quite sure how it works.
Thank you for you reply!
