Cisco Router 1800/Cisco Switch 2960
j_j624001
Hello;
I hope someone can provide me with extreme help on getting an internal network up and running; i had one internal network up and running before; but it seems like my second network were lagging and timing out then one day at work i had a power surge when i got home that cause a major shutdown all my equipment which i was unable to save configuration on my router and switch. So at this point im kinda stuck on what else i need to do. I was able to do a test on one of my computers; and at first my dhcp on my router was unable to provide my computer an ip address; so i had to change my computer to a static ip in order to connect to my router; once it was connected to my router i wasn't unable to connect to the internet; so after reviewing my configuration on the switch and router i was unable to pinpoint the problem if it was on the switch or on the router. Hopefully someone can provide some advice on what i need to do or change in order to get my internal network up and running. Listed below is my configuration of my router and switch please help !!!!!!!!!
Router config
ersion 12.4
hostname R
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
clock calendar-valid
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.0.1 10.10.0.49
ip dhcp excluded-address 10.10.0.75 10.10.0.255
ip dhcp pool R_POOL
import all
network 10.10.0.0 255.255.255.0
update dns
default-router 10.10.0.1
dns-server 192.168.0.1
domain-name R.com
update arp
interface FastEthernet0
description OUT
ip address 192.168.0.80 255.255.255.0
ip access-group 100 out
ip nat outside
ip virtual-reassembly
speed auto
full-duplex
vlan-id dot1q 192
description OUT
pppoe enable
exit-vlan-config
interface FastEthernet1
ip address 10.10.0.1 255.255.255.0
ip access-group 100 in
ip nat inside
speed 100
full-duplex
vlan-id dot1q 10
description IN
pppoe enable
exit-vlan-config
interface FastEthernet1.92
description OUT
encapsulation dot1Q 192
ip address dhcp client-id FastEthernet0
ip nat inside
no snmp trap link-status
pppoe enable group global
interface Vlan192
no ip address
ip verify unicast source reachable-via any
ip mask-reply
ip accounting output-packets
ip nat outside
interface Vlan10
no ip address
ip nat inside
ip route 0.0.0.0 0.0.0.0 (Public IP)
ip nat pool pool1 192.168.0.80 192.168.0.255 netmask 0.0.0.0
ip nat inside source list 100 pool pool1
access-list 100 remark NAT Rule
access-list 100 permit tcp 0.0.0.0 255.255.255.0 eq domain any
access-list 100 permit tcp 0.0.0.0 255.255.255.0 eq www any
access-list 100 permit tcp 0.0.0.0 255.255.255.0 eq 443 any
access-list 100 permit tcp 0.0.0.0 255.255.255.0 eq 8080 any
access-list 100 permit ip 0.0.0.1 255.255.255.0 any
access-list 100 permit udp 0.0.0.1 255.255.255.0 any
access-list 100 permit tcp 0.0.0.1 255.255.255.0 any
Switch Config
hostname S1
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1998
no ip subnet-zero
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/12
description test 192
switchport access vlan 192
switchport trunk native vlan 192
switchport trunk allowed vlan 192
switchport trunk pruning vlan 192
switchport mode trunk
switchport nonegotiate
switchport port-security mac-address sticky
shutdown
speed 100
duplex full
spanning-tree portfast trunk
spanning-tree bpdufilter disable
spanning-tree bpduguard disable
description test 10
switchport access vlan 10
switchport trunk native vlan 10
switchport trunk allowed vlan 10
switchport trunk pruning vlan 10
shutdown
speed 100
duplex full
interface GigabitEthernet0/1
description Out-to-WAN
speed 1000
duplex full
interface GigabitEthernet0/2
description TRUNK-to-FE0/1
speed 100
duplex full
interface Vlan10
description IN
ip address 10.10.0.2 255.255.255.0
ip mask-reply
ip information-reply
ip security dedicated unclassified genser
ip security add
ip security first
no ip route-cache
interface Vlan192
description OUT
ip address dhcp client-id Vlan192
ip mask-reply
ip security add
ip security first
no ip route-cache
ip tcp adjust-mss 1460
50 Replies 50
I am here. How is your network? is it working well?
Hello;
So far it seems be workin fine; i haven't had any issue lately thanks to you; yes it working well; but my next item that i would like to do is mainly secure certain ports on my inside and outside interface that we discussed a week ago.
So i tried and tried and tried different configurations  difference scenriaos far as my access-list to allow only certain ports  in and out.
What i would like to do on my outside interface is have only port 7,53, 80, 443, and 8080 allowed; where as my inside internal interface i would like to have port 7,21,22,23,25,53,67,80,110,123,143,443,1500,1501, and 8080; yes i know ports by the back of my head and these are the only port i want to be allowed inside my interface so all my computers/servers can talk/share/ping/ftp etc etc to each other.
Any ideas that could help ??
Can you open a new post? I have really hard time to find your comment here.
Its title the same as you posted in your previous comment.
its called
Cisco Router 1800/Cisco Switch 2960 Access List Help !!!!!!!!!!!!
Just lets go over port security.
First shut down any ports which you do not use.
You can add mac of your devices to switch. If any mac-address except the ones you configured come to your switch, switch disable that port.
Do the following step.
1- find your Laptop Mac-address
2- interface g0/10   [ Only for PC and server)
switchport mode access
switchport port-security mac-address 001b.d41b.a4d8  (your laptop mac address)
switchport port-security maximum 1
Now, if you attach any other PC or laptop, switch shuts port g0/10
Try with one interface at the first.
Masoud
Your all client are attached to that switch by ethernet cable? You have only LAN client?
Do you have any other clients like dial up wireless, DSL?
All of your clients have the IP of address of 10.10.x.x?
Masoud
