cisco router 1841 internet issues
I have configured 1841 router yesterday but internet is connected
public ip assigned in fa0
nat inside outside configured
dhcp pool configured
showing internet access in network setting
ISSUE : google search working but no other website open showing not reachable
(I have tried diffrent dns 8.8.8.8 and 4.2.2.2 but no luck but internet speed test website working and showing 90mbbs speed) internet provieder jio enterprise
I have shared  Configuration below please check and anyone give me the solution please.. thank you in advance.
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.5.2 10.0.5.40
ip dhcp excluded-address 10.0.0.1 10.0.1.1
ip dhcp pool scadcet
network 10.0.0.0 255.255.248.0
default-router 10.0.5.1
dns-server 49.45.0.4 8.8.8.8
ip name-server 8.8.8.8
interface FastEthernet0/0
ip address 136.232.209.10 255.255.255.252
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.0.5.1 255.255.248.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clockrate 125000
interface Serial0/0/1
no ip address
shutdown
clockrate 125000
ip classless
ip route 0.0.0.0 0.0.0.0 0.0.0.0
ip route 0.0.0.0 0.0.0.0 136.232.209.9
ip http server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 10.0.0.0 0.0.255.255
control-plane
line con 0
password scad
line aux 0
line vty 0 4
password scad
login
end
3 Accepted Solutions
make the changes/additions marked in bold:
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
--> ip dhcp excluded-address 10.0.5.1
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip address
shutdown
clockrate 125000
no ip address
shutdown
clockrate 125000
ip classless
--> no ip route 0.0.0.0 0.0.0.0 0.0.0.0
ip http server
control-plane
line con 0
password scad
line aux 0
line vty 0 4
password scad
login
end
Hello
You have dns forwarding enabled but your rtr is not configured:to forward correclty for clients to use your ISP DNS,
Try the following:
no dns-server 49.45.0.4 8.8.8.8
dns-server 10.0.5.1
no access-list 1 permit 10.0.0.0 0.0.255.255
no ip name-server 8.8.8.8
no ip route 0.0.0.0 0.0.0.0 136.232.209.9
access-list 1 permit 10.0.0.0 0.0.7.255
ip route 0.0.0.0 0.0.0.0 fa0/0 136.232.209.9
ip dns-server
Kind Regards
Paul
Thank you now working fne i have done the below changes
ip dns-server
Now working fine
But i cant take telnet any one please help me,,
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip address
shutdown
clockrate 125000
no ip address
shutdown
clockrate 125000
ip classless
ip http server
control-plane
line con 0
password scad
line aux 0
line vty 0 4
password scad
login
end
@Georg Pauwen
FYI- Not really applicable to exlcude the default-gaetway address from dhcp alllocation as its done by default
Kind Regards
Paul
ip dns-server
Now working fine
Hello
Try the following:
dns-server 10.0.5.1
ip dns-server
Kind Regards
Paul
