Cisco router 1921/k9 internet connection dropping
arubio4
Hello i have cisco 1921/k9 when i first do a factory reset and configure  the router the internet works until the next day then i have no internet connection. I am using cable modem connection with spectrum which is my isp.
i am using the following commands
conf t
int g0/0
ip address dhcp i obtain ip on fresh erase if i try to issue the command the router wont obtain an ip from the modem
also I would like to add that I tried to add static ip and did not work
5 Replies 5
Hello @arubio4 ,
Have you tried asking the ISP? Is this the ISP recommended configuration for your router?
Regards, LG
*** Please Rate All Helpful Responses ***
I am on dynamic ip address from isp
debug dhcp packet <<- share this
MHM
Which commands should i use for that
debug dhcp packet
MHM
