cisco router 2900 giving warning error
zeeshanzahid510
Kindly suggest what to do.
After login router 2900 continuously giving same msgs
"fan tray was removed. Please re-insert fan tray  to prevent overheating "
It was in running condition.
unable to run any command as it is continuously giving same warnings.
balaji.bandi
May be worth - Turn off the device clearn the FAN filters and Turn on the device : (depends on the Location)
https://www.cisco.com/c/en/us/td/docs/routers/access/2900/hardware/installation/guide/Hardware_Installation_Guide/Internal_Modules.html#24227
BB
Martin L
Clean fans and connectors and re-install fans or get new /used fan tray to replaced old one.  If temp is steady the same, maybe this is falls positive.
Regards, ML
**Please Rate All Helpful Responses **
