cisco router 3925 create xconnect on sub port-channel
unfraget
hi everybody
i have router 3925 with IOS version c3900-universalk9-mz.SPA.156-3.M4.bin
Technology Package License Information for Module:'c3900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      None                 None           None
uc            uck9                 Permanent      uck9
data          datak9               Permanent      datak9
and i'm trying create xconnect on sub port channel interfacem, but i can't do it, under sub interface configuration mode absent context xconnect:
(config)#int po1.100
(config-subif)#en
(config-subif)#encapsulation do
(config-subif)#encapsulation dot1Q 100
(config-subif)#x
(config-subif)#x?
% Unrecognized command
how to create xconnect on sub port-channel?
6 Replies 6
is the data license (which I think is required for xconnect) active and in use ?
3925#show license
should show something like this:
Index 4 Feature: datak9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Hello
yes, data licence is active
#sh license
Index 1 Feature: ipbasek9
Index 2 Feature: securityk9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
Index 3 Feature: uck9
Hello unfraget,
you have the correct licenses installed and active.
I have a question :
the member links of po100 are taken from router ports of the C3925 or are switched ports of an etherswitch module installed on the C3925?
I think this can make the difference between support and lack of support.
Hope to help
Giuseppe
Hi!
my CISCO3925 hasn't an additional module, all port is embedded
Hello
Looks like ios version incompatibility problem
Kind Regards
Paul
Hello
which version is needed?
