Cisco router 800 series configuration
junaid haroon
I have router 800 series.I has only one ethernet interface.I need one ethernet inface for WAN and one for LAN. Can i achive this by dividing the one interface into multiple subinterfaces.
I need one interface for Dailer configuration for WAN connectivity.And one for LAN.
Please advise.
Giuseppe Larosa
Hello Junaid,
with the appropriate IOS image there is support of the PPPoX over a vlan based subinterface. However, you will need an external L2 LAN switch that supports Vlans and 802.1Q vlan tagging.
What exact model is your router?
What IOS image is running on it?
You can post  show version output that contains both requested informations
Hope to help
Giuseppe
Hi Giuseppe,
Below is result of sh version command.
Cisco IOS Software, C837 Software (C837-K9O3Y6-M), Version 12.3(7)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Sat 21-Feb-04 14:37 by eaarmas
ROM: System Bootstrap, Version 12.2(8r)YN, RELEASE SOFTWARE (fc1)
Router uptime is 8 minutes
System image file is "flash:c837-k9o3y6-mz.123-7.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C837 (MPC857DSL) processor (revision 0x500) with 44237K/4915K bytes of memory.
Processor board ID AMB08190LA6 (4135788765), with hardware revision 0000
CPU rev number 7
1 Ethernet interface
1 ATM interface
128K bytes of NVRAM.
12288K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
