Cisco Router and Switch
Hi all,
We are building a small Cloud DC and we need some Router that have BGP/GRE/mGRE speed from 1-2GBps and a Switch Layer 3 that will be compatible and will be as backbone. So what i like to ask is some suggestions and also i like to know whot can i choose the righte one. I have bean put many times in this postion to choose the equipment, but for me the one that have everything is excelent choice :D. How can i find the right one ?
Thanks in advanced !
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising  out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The high end of the ISR 4400 series, can handle 1 to 2 Gbps, but if you want to invest in additional capacity, the entry models in the ASR 1000 series should serve your needs.  (NB: with some of the entries ASR 1000 series, you can also support 10g.)
Recommending a L3 switch is tougher because they are more for oriented for specific needs and performance ranges.  You only mentioned Cloud DC, L3 and backbone; not much to narrow down a recommendation.  For DC usage, Cisco has their Nexus line. For (a small) backbone, perhaps something in the 4500 or 4900 families.  Both lines/families have devices that support L3.
Well we have 4 OpenStack enviroments, we have 3 VMWare enviroments and 2 Hyper-V enviroments. We have 7 Racks with 20 Servers and every Rack have 6 switches. So what i want to make is all of this switches somehow get to the the main one and from there to go throught the Router. We have 4 lines with 1GBps with BGP. If we increes the speed will be 2 GB maybe 4 in the future. So we will go with 1GB for now.
What about 1941 and 1921 for the Routers ? I would not say small for the Switch :). And also the main question is how to choose ? What question to aks myself and how can you say you can use ISR or ASR ? What to look for so i can make the decisions ? :?
Disclaimer
Posting
For ISR selection, you might find the following helpful: https://supportforums.cisco.com/sites/default/files/legacy/0/3/8/142830-white_paper_c11_595485.pdf
Unfortunatelly predates the 4400 series and doesn't have ASR either, but it does have the 1900 series.
