Cisco router as PPTP Client, unable to browse internet
ikorzha
Hi to all, I have the following issue:.
I have a cisco 1921 that I am planning to use as PPTP client to connect to PPTP server that has internet connectivity.
I get PPTP tunnel established, but clients on local segment of PPTP client cisco router 192.168.15.0/24 are unable to reach internet.
My current config below:
Any suggestions how to fix this simple problem would be greatly appreciated
------------------ show version ------------------
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.5(3)M6a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Mon 25-Sep-17 06:12 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
papan uptime is 9 minutes
System image file is "flash:c1900-universalk9-mz.SPA.155-3.M6a.bin"
Last reload type: Normal Reload
Last reload reason: power-on
Building configuration...
Current configuration : 2708 bytes
! Last configuration change at 01:48:04 UTC Sat Dec 2 2017
version 15.5
service internal
hostname papan
boot-start-marker
boot system flash:c1900-universalk9-mz.SPA.155-3.M6a.bin
boot system usbflash0:c1900-universalk9-mz.SPA.155-3.M6a.bin
boot-end-marker
no aaa new-model
ethernet lmi ce
ip dhcp excluded-address 192.168.15.1
ip dhcp pool 1
 network 192.168.15.0 255.255.255.0
 dns-server 8.8.8.8
 default-router 192.168.15.1
 lease 1 6
ip domain name home
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip name-server 4.2.2.2
ip cef
no ipv6 cef
vpdn enable
vpdn-group pptp
 request-dialin
  protocol pptp
  pool-member 1
 initiate-to ip 100.100.100.50
cts logging verbose
license accept end user agreement
username network privilege 15 secret 5 <removed>
redundancy
 notification-timer 120000
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description INTERNET
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description INSIDE NETWORK
 ip address 192.168.15.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface Dialer0
 ip address negotiated
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer remote-name pptp-Igor
 dialer idle-timeout 0
 dialer string 1234
 dialer persistent
 dialer vpdn
 dialer-group 1
 ppp pfc local request
 ppp pfc remote apply
 ppp authentication ms-chap ms-chap-v2 optional
 ppp chap hostname administrator
 ppp chap password 0 <removed>
 no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map DIALER0_PRIMARY interface Dialer0 overload
ip nat inside source route-map ISP_SECONDARY interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 100.100.100.50 255.255.255.255 GigabitEthernet0/0 dhcp
ip ssh version 2
dialer-list 1 protocol ip permit
route-map DIALER0_PRIMARY permit 10
 match ip address 100
 match interface Dialer0
route-map ISP_SECONDARY permit 10
 match interface GigabitEthernet0/0
access-list 100 permit ip 192.168.15.0 0.0.0.255 any
control-plane
 vstack
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input ssh
scheduler allocate 20000 1000
end
at first glance, it looks like your static routing is reversed. I have made some changes (in bold), see if that makes a difference:
version 15.5
service internal
hostname papan
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip dhcp pool 1
dns-server 8.8.8.8
lease 1 6
ip domain name home
ip cef
no ipv6 cef
vpdn enable
vpdn-group pptp
request-dialin
protocol pptp
rotary-group 1
cts logging verbose
redundancy
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface Dialer1
ip nat outside
encapsulation ppp
dialer-group 1
dialer string 1234
dialer persistent
dialer vpdn
dialer-group 1
no cdp enable
no ip http server
ip classless
ip nat inside source route-map DIALER1_PRIMARY interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
ip route 100.100.100.50 255.255.255.255 Dialer1
ip ssh version 2
route-map DIALER1_PRIMARY permit 10
match interface Dialer1
control-plane
vstack
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
transport input ssh
Thank you for your response, I tested the proposed solution, unfortunately something is missing in it.
Since PPTP tunnel doesnt come up currently "Virtual-Access" interface doesn't come up..due to rotary-group 1
When I remove rotary-group 1, tunnel comes up,  local users can browse the internet but NOT thru the dialer1 interface..
Looking for further suggestions from you, thank you in advance :)
papan#sh int dialer 1
Dialer1 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Internet address will be negotiated using IPCP
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:14:34
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes
     0 packets output, 0 bytes
NVI0 is up, line protocol is up
  Hardware is NVI
  MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
  Encapsulation UNKNOWN, loopback not set
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
Posting current config for reference
! Last configuration change at 13:46:11 UTC Sat Dec 2 2017
version 15.5
service internal
hostname papan
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip dhcp pool 1
 dns-server 8.8.8.8
 lease 1 6
ip domain name home
ip cef
no ipv6 cef
vpdn enable
vpdn-group pptp
 request-dialin
  protocol pptp
  rotary-group 1
cts logging verbose
license udi pid CISCO1921/K9 sn FJC2011L0EA
redundancy
 no ip address
 shutdown
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
interface Dialer1
 ip nat outside
 encapsulation ppp
 dialer string 1234
 dialer persistent
 dialer vpdn
 dialer-group 1
 ppp chap password 7 xxxxxxxxxxxxxxxxxxx
 no cdp enable
no ip http server
ip ssh version 2
control-plane
 vstack
line con 0
line aux 0
line 2
 no exec
 stopbits 1
line vty 0 4
 login
 transport input ssh
ntp server pool.ntp.org
end
papan#
try your original routing again:
ip route 0.0.0.0 0.0.0.0 Dialer1
