Cisco router can connect to internet but any connected devices can't
Karakas
I've got my isp router connected to the cisco router (897 VA-VAB). The Cisco router gets internet normally and pings sites accordingly but any connected device doesn't have inernet. Here is my currently running configuration:
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
memory-size iomem 10
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.3.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.128
default-router 10.10.10.1
lease 0 2
ip dhcp pool 192.168.1.0 255.255.255.0
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 4.2.2.2
ip dhcp pool NewPool
import all
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
no ip domain lookup
ip domain name yourdomain.com
ip name-server 8.8.8.8
ip name-server 4.2.2.2
ip cef
no ipv6 cef
cts logging verbose
license udi pid C897VAB-K9 sn FCZ2229E352
vtp version 2
username karakas privilege 15 secret 5 $1$/iTv$MydhEFx5bow43C/pA2gbN1
controller VDSL 0
no cdp run
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
ip address 192.168.1.2 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
description $ETH_LAN$
ip address 192.168.3.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat source list 1 interface GigabitEthernet8 overload
ip nat inside source list 1 interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
tftp-server flash:/firmware/vdsl_bond.bin
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner exec ^C
2 Accepted Solutions
Only acces list 1 is missing
MHM
Try --> access-list 1 permit 192.168.3.0 0.0.0.255
Permit your lan subnet in access list
HTH!!!
MHM
Thank you
HTH!!!
Karakas
Thank you very much this was it
