Upgrade Cisco IOS ASR 1001-X
phil.g.james
Hi we have a requirement to upgrade a Cisco ASR1001-X router from version IOS15.5(3)S5 IOS XE 03.16.05 to asr1001x-universalk9.17.06.04.SPA.bin
Can we upgrade directly to this version or will be have to implement an intermediate version in-between the two?
8 Replies 8
M02@rt37
Hello @phil.g.james,
check your ROMMON version and see if an upgrade of it is necessary
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/rommon/asr1000-rommon-upg-guide.html
Best regards
Leo Laohoo
Direct upgrade is supported as long as the ROMMON is upgraded first.
Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
Hi Leo,
The version 17.x (ASR1001-X) support upgrade via bundle mode?
I want to upgrade from 16.9.5 to 17.9 via bundle mode , is it possible ?
Bundle Mode upgrade, from 16.9.X, to 17.9.X is supported as long as the ROMMON gets upgraded first.
NOTE:
Some people may state that the ROMMON will get "automatically" upgraded, I would not risk it because I've already seen in 17.12.X where the ROMMON did not get "automatically" upgraded to 17.7.1r and the router went into a boot-crash-loop as a consequence of this "undocumented feature".
Hi Leo,
Could you please provide the detailed steps/commands for the Bundle Mode upgrade, from 16.9.4, to 17.9.5a ?
Use Install Mode instead.
kakashiHatake
Hi @Leo Laohoo ,
Can we upgrade directly from bundle mode to install mode by simply following the install mode upgrade steps, or is there a specific method we need to follow?
@kakashiHatake wrote:
Hi @Leo Laohoo ,
Follow the guide I have posted to upgrade from Bundle Mode to Install Mode.
NOTE:
Do not conduct a direct upgrade from 17.3.X (and earlier) to 17.12.X (and later) because the router may go into a boot-crash-loop.  Upgrade first to an intermediate version, like 17.6.X or 17.9.X, before making the upgrading to 17.12.X (and later).
