Cisco ROUTER ISR 4331
rohitelegance
     Myself rajesh Singh and i was using router 2951 but after some hardware issue i buy a new router ISR4331. When i tried to move my configuration from 2951 => 4331 some of the commands are not allow to accept on this new router. Here are the command in RED color which are not accepted by new router:-
policy-map VOIP
class sdm_p2p_edonkey
drop
class sdm_p2p_gnutella
drop
class sdm_p2p_kazaa
drop
class sdm_p2p_bittorrent
drop
class VoIP-RTP-Trust
priority percent 70
class VoIP-Control-Trust
bandwidth percent 5
class class-default
fair-queue
random-detect
policy-map sdmappfwp2p_CCP_HIGH
drop
drop
class sdm_p2p_kazaa
drop
drop
no ip bootp server
ip domain name "domain namexxxxxxxxx"
ip inspect log drop-pkt
ip inspect name outbound https
ip inspect name outbound ftp
ip inspect name outbound ftps
ip inspect name outbound dns
ip inspect name outbound icmp
ip inspect name outbound tcp
ip inspect name CCP_HIGH appfw CCP_HIGH
ip inspect name CCP_HIGH icmp
ip inspect name CCP_HIGH dns
ip inspect name CCP_HIGH esmtp
ip inspect name CCP_HIGH https
ip inspect name CCP_HIGH imap reset
ip inspect name CCP_HIGH pop3 reset
ip inspect name CCP_HIGH sip
ip inspect name CCP_HIGH h323
ip inspect name CCP_HIGH tcp
ip inspect name CCP_HIGH udp
no ipv6 cef
interface Embedded-Service-Engine0/0
no ip address
shutdown
ip sla auto discovery
snmp-server community india RO
snmp-server enable traps entity-sensor threshold
scheduler allocate 20000 1000
Please suggest me how can i use these commands or instead of these commands what can i use on 4331.
mvsheik123
Level 7
Level 7
Hi Rajesh,
Looks like you are missinf required voice and security bundle code on 4331. Compare the codes on both routers (although not identical, you may be able to figure it out). Check the below link for 4K series bundles..
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/guide-c07-732797.html#_Toc493015841
hth
MS
