cisco router isr4221 ios difference is qos function?
EuiGwan6260
Are there any differences in Qos function when updating isr 4221 router ios?
If there is a difference, which function was added, and I would appreciate it if you could send me the Qos function table of isr4221.
Thak you for your help.
Mark Elsen
 - You won't find a dedicated table. Check Release Notes for targeted version and look for qos with browser-find (for instance).
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
Depends on what version you moving FROM to TO
Older to new MLS / MQC were changed
but as suggested you can also looking release notes.
BB
