Cisco router keeps de-compressing and does not save
Bobns
The router would first only boot onto rommon mode. This has been solved with these steps:
  1. Shut the router down.
  2. Remove the compact flash from the back of the router.
  3. Turn the router back on.
  4. When you see the Rommon1> prompt, enter the command of confreg 0x2142.
  5. Insert the compact flash.
  6. Type reset.
  7. When prompted to enter the initial configuration, type no and press enter.
After this the router wil load normally but doesn't save anything when I use the commando's copy run start etc. It is an CISCO 1841 Router this is what happens when I boot it:
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 platform with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x16474e4
Self decompressing the image : ############################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ         TYPE
                0X003AA110 public buffer pools
                0X00211000 public particle pools
                0X00020000 Crypto module pools
0X002E          0X00035000 Card in slot 0
                0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 6568963 bytes to IO Memory.
PMem allocated: 118489088 bytes; IOMem allocated: 15728640 bytes
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(23), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sat 08-Nov-08 20:07 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1841 (revision 7.0) with 115712K/15360K bytes of memory.
Processor board ID FCZ1305111T
2 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
         --- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: no
Press RETURN to get started!
sslinit fn
*Mar 28 13:12:22.415: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Initialized
*Mar 28 13:12:22.419: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Enabled
*Mar 28 13:12:28.483: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Mar 28 13:12:28.499: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*Mar 28 13:12:34.023: %SYS-5-RESTART: System restarted --
*Mar 28 13:12:34.027: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
*Mar 28 13:12:34.335: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Mar 28 13:12:35.395: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively down
*Mar 28 13:12:35.395: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
*Mar 28 13:12:35.399: %LINK-5-CHANGED: Interface ATM0/0/0, changed state to administratively down
*Mar 28 13:12:36.399: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0/0, changed state to down
Personally I think it is because of this. But I don't know how to fix it:
Thanks in advance!
 This is the expected behavior.  After touter  come up, you need to change the config register again.
the value 0x2142 ignores the NVRAM memory.
You need to use the 0x2102
Router# configure terminal
Router(config)# config-register 0x2102
This was the solution. Thank you very much!
