Cisco Router not reachable to LAN
arthurny
I'm new to router configuration and i've basically been following the summary steps on the Cisco site to configure a new Cisco 4221/K9 router with IOS XE Software, Version 16.12.03. My LAN has 2 subnets, 192.168.0.0/24 and 192.168.1.0/24. The latter is the subnet with my networking devices including the LAN facing interface of the router: 192.168.1.1. After basic configurations, i was able to ping outside addresses including my DNS and router's default gateway on 196.43.116.49 (both assigned by ISP) but i cannot ping the any internal addresses. I also cannot ping the router from the LAN. I'm unsure of my NAT configuration but somewhere there must be a mistake or omission. Please help!!! Below is my running config:
Router#show run
Building configuration...
Current configuration : 5887 bytes
! Last configuration change at 06:58:17 UTC Wed Feb 16 2022 by admin
version 16.12
no service pad
service password-encryption
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
platform inspect match-statistics per-filter
hostname Router
boot-start-marker
boot-end-marker
vrf definition 65528
address-family ipv4
exit-address-family
logging buffered 262144
no logging rate-limit
no aaa new-model
fhrp version vrrp v3
no ip source-route
ip name-server 196.43.100.37 41.190.32.21
no ip dhcp use class
ip dhcp excluded-address 192.168.1.0
ip dhcp excluded-address 192.168.1.255 255.255.255.255
ip dhcp pool WEBUIPool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
no ip igmp ssm-map query dns
login on-success log
ipv6 unicast-routing
subscriber templating
domain permit
crypto pki trustpoint TP-self-signed-157559341
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-157559341
revocation-check none
rsakeypair TP-self-signed-157559341
license udi pid ISR4221/K9 sn FGL2521L7FL
no license smart enable
memory free low-watermark processor 67180
diagnostic bootup level minimal
username admin privilege 15 secret 9 $14$fRWB$mo5V/T24gf8FDk$27FQF0sQFFispPzzmkE8crWP0RpC2.PZy6qKZYmGhCM
username cisco password 7 08705F5C5D4B5746
redundancy
mode none
no crypto ikev2 diagnose error
interface Loopback65528
vrf forwarding 65528
ip address 192.168.1.1 255.255.255.255
interface GigabitEthernet0/0/0
description GE interface to WAN
ip address 196.43.116.50 255.255.255.0
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
description GE interface to LAN
ip address 192.168.1.1 255.255.255.252
ip nat inside
negotiation auto
ip default-gateway 196.43.116.49
ip forward-protocol nd
ip http server
ip http port 8080
ip http access-class 20
ip http authentication local
ip http secure-server
ip http max-connections 10
ip http timeout-policy idle 60 life 120 requests 100
ip http client source-interface GigabitEthernet0/0/1
ip http client proxy-server server1 proxy-port 52
ip http path slot1:
ip nat route vrf 65528 0.0.0.0 0.0.0.0 global
no ip nat service skinny tcp port 2000
no ip nat service sip tcp port 5060
no ip nat service sip udp port 5060
no ip nat service H225
no ip nat service ras
no ip nat service rtsp udp
no ip nat service rtsp tcp
no ip nat service dns tcp
no ip nat service dns udp
no ip nat service netbios-ns tcp
no ip nat service netbios-ns udp
no ip nat service netbios-ssn
no ip nat service netbios-dgm
no ip nat service ldap
no ip nat service sunrpc udp
no ip nat service sunrpc tcp
no ip nat service msrpc tcp
no ip nat service tftp
no ip nat service rcmd
no ip nat service pptp
no ip nat service ftp
no ip nat service gatekeeper
no ip nat service dns-reset-ttl
ip nat pool net-208 192.168.0.0 192.168.1.254 netmask 255.255.0.0
ip nat inside source static 192.168.1.1 196.43.116.50
ip nat inside source list NAT_THESE_ADDRESSES pool net-208 overload
ip route 0.0.0.0 0.0.0.0 196.43.116.49
ip ssh version 2
ip scp server enable
ip access-list standard NAT_THESE_ADDRESSES
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
login local
transport input none
stopbits 1
line aux 0
login local
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 80
login local
transport input ssh
netconf-yang
netconf-yang feature candidate-datastore
end
Thanks for the help
make the changes marked in bold:
version 16.12
no service pad
hostname Router
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
no aaa new-model
no ip source-route
--> no ip dhcp excluded-address 192.168.1.0
--> no ip dhcp excluded-address 192.168.1.255 255.255.255.255
--> ip dhcp excluded-address 192.168.1.1
domain permit
redundancy
mode none
ip nat outside
negotiation auto
ip nat inside
negotiation auto
--> no ip default-gateway 196.43.116.49
ip http server
ip http port 8080
ip http path slot1:
--> no ip nat pool net-208 192.168.0.0 192.168.1.254 netmask 255.255.0.0
--> ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip ssh version 2
--> access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
login local
stopbits 1
line aux 0
login local
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 80
login local
transport input ssh
netconf-yang
end
version 16.12
no service pad
hostname Router
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
no aaa new-model
no ip source-route
domain permit
redundancy
mode none
ip nat outside
negotiation auto
ip nat inside
negotiation auto
ip http server
ip http port 8080
ip http path slot1:
ip ssh version 2
control-plane
line con 0
login local
stopbits 1
line aux 0
login local
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 80
login local
transport input ssh
netconf-yang
end
Sweet success. I can now ping all addresses local and global from within my LAN, except my public IP's default gateway for some reason. I now have internet access via the router too. Thank you very much
You said this network was a /24, why have you configured the interface as a /30?
Have you mixed up the masks for the WAN and LAN interfaces?
I will need to rectify that mask in the NAT because i only have 2 addresses I use in that subnet. The rest of the LAN is in the 192.168.0.0 network. But since its working, i'm uneasy about making further changes lest i find myself in a fix again
