Cisco router selection query || Need urgent help
imranul hoque
I am working to deploy cisco router to one of my project. Please help/suggest me to choose a model that meet below specification-
Minimun specification requirement as below-
1U Chassis Rack Mountable.
The Router should have minimum 4x 1 Gigabit Ethernet WAN ports and 4-port Layer 2 GE Switch Network Interface Module.
minimum 1 NIM slot for future upgradable.
Router should support at least IPv4 Forwarding minimum upto 25M (Aggr, 50M)
should support IPv4 Forwarding Throughput scalable up to 3.5Gbps and IPsec Throughput scalable up to 500 Mbps.
Number of IPsec VPN Tunnels minimum 1500.
Router should have DRAM 8GB
Router should have onboard Flash storage minimum 2GB.
Number of ACLs per system: 4000
Number of IPv4 ACEs per system: 70K
Number of IPv4 Routes: 750,000
Number of IPv6 Routes: 750,000
Number of Queues: 15K
Number of NAT Sessions: 550,000
Number of VRFs: 1800
Number of firewall sessions 510,000.
Fixed Power Supply.
Should have IPv4, IPv6, static routes, RIP and RIPv2, OSPF, EIGRP, BGP, BGP Router Reflector, IS-IS, IGMPv3, PIM SM, SSM, RSVP, ERSPAN, IPSLA, EEM, IKE, ACL, EVC, DHCP, Frame Relay, DNS, LISP, HSRP, RADIUS, Authentication, Authorization, and Accounting (AAA), AVC, DVMRP, IPv4-to-IPv6 Multicast, MPLS, Layer 2 and Layer 3 VPN, IPsec, L2TPv3, BFD, IEEE 802.1ag, and IEEE 802.3ah.
Imran
M02@rt37
Hello @imranul hoque
check C8200 series routers:
https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8200-series-edge-platforms/nb-06-cat8200-series-edge-plat-ds-cte-en.html
Best regards
balaji.bandi
Looks you copied most of the spec from Cat 8K model of cisco.
BB
imranul hoque
Fixed Power Supply.
Imran
Leo Laohoo
Get a reputable systems integrator.
https://community.cisco.com/t5/network-security/cisco-ngfw-selection-query-need-urgent-help/m-p/4924492
https://community.cisco.com/t5/switching/cisco-switch-selection-query-need-urgent-help/m-p/4924494
Base on the number of threads created, you are out of your depth.  One wrong move and it will cost you a fortune to correct.
