Cisco Router support 24 E1 (Ethernet port)
Med Aly
I use E1/Ethernet conveter 8 port for my internet link and want to replace this converter by cisco router support 24 E1(ethernet port).
could you please suggest  for me wich router model can I use for this?
Leo Laohoo
What is your total WAN speed?
the total speed 100 Mbps
100 Mbps?  You need at least a 3945 or 3925E router.
thanks Leo for your answer
I have the E1s separated, now i have 24 E1 so I will need 24 port Ethernet to terminate all my 24 E1s, at total now the total sppeed is 48 Mbps, but  I plan to expend this capacity later to 100 Mbps, thats way I tald you the total capacity is 100 Mbps.
can we have 24 port Ethernet for this router model and in witch module? thank you in advance.
