cisco router
BilalButt62333
Which cisco router has ike(internet key exchange) version 2 in SMB or Branch routers or ISR series
if any kindly update me asap, Thanks
Leo Laohoo
All of them.
I have 1841 model but in datasheet no mention of version 2 also in others
models datasheet , can you help me find out how to detect version 2
available or not so kindly let me know is there any command to check or
activate it
@BilalButt62333 wrote:
I have 1841 model but in datasheet no mention of version 2 also in others models datasheet
If the routers have the right IOS, have the correct amount of DRAM and Flash, it can/will support IKEv2.
The question that you need to ask if whether or not the router came with a dedicated (optional) encryption card or not.
ISR G1, by default, does not have a dedicated encryption card so all the encryption is processed by the CPU.
johnlloyd_13
Level 9
Level 9
just to add, the ISR router will support IKEv2 once the necessary security license has been applied.
you can apply the temporary eval license to test it out.
