Bookmark
Subscribe
517
cisco router
BilalButt62333
I have the following scenario:
1. old Router(fast 0/0)---switch---PC
in this scenario, pc IP has 10.10.0.86 and can ping router IP 10.10.10.25
2. New Router(gig 0/0)---switch---PC
in this scenario, pc can't ping while the same IP and same config on the new router
pc can ping the old router IP(10.10.10.25) but when a new router attach with the same config pc can't ping, if pc attached directly while the pc IP (10.10.10.25) with the new router  gig 0/0 it can ping
on router eth fast 0/0 has config:
IP address 10.10.10.25 255.255.255.248
IP nat inside
IP virtual-reassembly in
duplex auto
speed auto
pc has IP 10.10.0.86
NetworkDave
BilalButt62333,
Verify the IP settings in the PC and Routers.
IP 10.10.10.25 ?                        10.10.0.86?
255.255.255.248?                     Subnet mask ?
                                                 Gateway ?
      IP Address?                           IP Address?
      Subnet mask ?                      Subnet mask ?
      Gateway ?                             Gateway ?
Is the PC's IP address 10.10.0.86 or 10.10.10.86 or 10.10.10.25?
You mentioned that router eth fast 0/0 has config:
      IP address 10.10.10.25 255.255.255.248 (is this correct?)
A Subnet Mask of 255.255.255.248 will only allow for a block of 8 IP addresses (1 Subnet ID, 6 Hosts, and 1 Broadcast). This puts the PC and router in different subnets.
You connected the PC (10.10.10.25) directly to the new routers interface (gig0/0); wasn't that the IP of the router's interface? Then what is the IP address of gig0/0?
What model are the old and new router? What model of switch? Any VLANs? if so, ROS or L3 Switch?
Please provide the running-config for both routers (old and new).
Remember to mark helpful posts and mark the correct answer as a solution; It helps other users with similar questions.
