Cisco Router
IrfanKhan4904
We are looking to buy a new router and have selected this model(C8200-1N-4T), so can anyone tell us how many port(Ethernet and SFP) this router has?
4 Accepted Solutions
@IrfanKhan4904
2 RJ45 + 2 SFP ports
Best regards
M02@rt37
@IrfanKhan4904
C8200-1N-4T has got NIM module. You should add C-NIM-2T to have 2 other RJ45 ports + 2 others SFP ports.
https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8300-series-edge-platforms/catalyst-8000-gigabit-ethernet-wan-modules-ds.html
Best regards
Joseph W. Doherty
Just curious, you've already selected a router to purchase but you don't know how many ports it provides?  Or, perhaps you just meant you're wondering whether this router might be suitable for your purchase depending on the ports it provides?
10 Replies 10
Ethernet ?
SFP ?
@IrfanKhan4904
Best regards
M02@rt37
@IrfanKhan4904
If you need more ports, check this model 8500L-8S4X. The C8500L-8S4X platform offers 4x 1/10GE and 8x 1GE ports :: full SFP.
You could plug GLC-TE if you need RJ45.
https://tmgmatrix.cisco.com/?npid=4021
Best regards
"It is very expensive. Our budget is 1.5 million, so kindly suggest a router with a minimum of 4 Ethernet ports and 4 SFP ports."
What is the expiration date of this router C8200?
Hello @IrfanKhan4904
No expiration date for that C8200 announced.
Best regards
M02@rt37
@IrfanKhan4904
Best regards
What is the expiration date of this router?
Joseph W. Doherty
