Cisco RV130 Router's slow NAT throughput
admin
According to Router's data sheet, its NAT throughput is 800mbps.Real NAT WAN-->LAN download/upload speed is maximum 170mbps.
(Firmware is latest, QoS is off, Internet connection 1 gbps).Whan can i do to increase this speed ?
P.S. During load the router's box is hot and it's CPU is about 98-100% load.(emergency events in it's log).
try different MTU settings (page 23 of the attached admin guide). Also, under QoS --> Bandwidth Management, make sure the upstream and downstream values match those given to you by your provider (page 111 of the guide):
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv130w/admin_guide/en/rv130w_admin_en.pdf
Also, the latest firmware is 1.0.3.28...I have attached the file in case you need it.
