cisco 3850 24Xs swicthes - can we make them into stack using 10G ports insted of stack ports.
Not applicable
cisco 3850 24Xs swicthes - can we make them into stack using 10G ports insted of stack ports.?
8 Replies 8
Leo Laohoo
Not supported.
Not applicable
Thanks for your reply Leo..
Not applicable
How about VSS feasibility on 3850? what IOS version will support VSS and can you provide me the configuration guide?
You've got to be joking right?  VSS on a 3850?
Stacking comes natively with 3850 and you want to do VSS?  You're "re-inventing the wheel".
Maybe the switches are miles apart :)...
Then you can use the 4500-X.  ;)
Not sure what all the new Catalyst 9K series supports beyond stacking similar to Catalyst 3Ks.
Only the 9500 will support Stackwise Virtual.
9400 will support VSS.
Only the WS-C3850-48XS can support Stackwise Virtual.  No other models can.
