10-22-2018 11:23 PM
Hello. I have a SSH server that accepts connections on a custom port. Port forwarding has been setup so that any connection to the static IP address will be forwarded to the internal IP address of the server. Recently I have blocked all outgoing connections with the following exceptions: HTTP, HTTPS, Teamviewer and the SSH Server port. Now I cannot connect to the SSH server using the external IP address. It only works if I use the internal one. I have used the rule BLOCK ALL - LAN ANY-to-ANY and an ALLOW rule for each exeption. If I disable the BLOCK ALL rule it will work fine.
What could be the problem?
10-23-2018 12:47 AM
Hi there,
From your description alone, it sounds like you have put the block ANY-ANY above your permit statements. Try re-ordering so that the permit statements for those specific services are at the top of the ACL.
cheers,
Seb.
10-23-2018 12:56 AM
can you post a screenshot of your access rules (similar to those displayed in the attached document) ?
10-23-2018 02:12 AM
10-23-2018 02:12 AM
10-23-2018 05:51 AM
Anyone?
10-23-2018 06:03 AM
I think you need a rule that goes to the other direction, from source interface WAN(1) to source and destination any/any...
10-23-2018 06:20 AM
10-23-2018 06:26 AM
What I mean is the same rules but specifying the WAN1 interface as the source, e.g.:
Action: Allow
Source: HTTP(80)
Source Interface: WAN1
Source: Any
Destination: Any
10-24-2018 06:23 AM - edited 10-24-2018 06:27 AM
The rule is already set up. Let's say the SSH server is running on IP 192.168.1.122 on port 1234. These are the firewall rules in the order of priority.
1. ALLOW - SSH [1234] - LAN - ANY <> ANY
2. DENY - ALL TRAFFIC - LAN - ANY <> ANY
3. ALLOW - SSH [1234] - WAN1 - ANY <> ANY
4. DENY - ALL TRAFFIC - WAN1 - ANY <> ANY
If I try to connect from an outside network to [external ip address]:1234 it works. It also works from the inside network for 192.168.1.122:1234. But when I try to connect from LAN to [external ip address]:1234 it fails. Disabling rule no. 2 allows me to successfully connect to [external ip address]:1234 from LAN. What could be the problem??
10-24-2018 06:27 AM - edited 10-24-2018 06:29 AM
Swap rules 2 and 3...
10-24-2018 06:36 AM
10-24-2018 10:33 PM
Could this be a firmware bug? If so who should I notify?
10-25-2018 01:18 AM
actually, you might be right, this could be a bug. I came across the one below (although only the RV13x is listed, it might as well apply to the 32x). Try a lower firware, I would start with the 1.3.2.02 release...
RV130x: Block Access Rule blocks traffic that should be Allowed
CSCuz56638
Description
Symptom:
- If an Allow ACL has been configured to allow traffic from a specific host/network and then a Block ACL is configured, the Block ACL will block traffic that is supposed to be Allowed
- This is seen even when Allow ACL is ordered first
Conditions:
- Allow ACL is configured
- Block ACL is configured
- Seen in 1.0.3.14
Workaround:
- Disable the Block ACL
- Downgrade to 1.0.2.7
