Cisco SB101 with SNMP
nicholsrn430
Ok, I am very new to routers. I am trying to enable the SNMP through the SDM utility, but there is little information in the screens on to what the best route is for this. I am trying to get the information off the router to a network monitoring utility.
carenas123
Level 5
Level 5
Because SDM uses a default configuration file, if you have used SDM to configure your router, it does not execute the standard Cisco IOS startup sequence.
