Bookmark
Subscribe
2615
Cisco SDM and SDM Express has stopped working...
mark
I have 3 Cisco 800 series rounters.
Lately the SDM configuration tool hangs when configuring the routers.
Can someone tell me how to update the firmware so they are current and work?
Here is the router software information…
Springland#show version
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(4)T8, REL
EASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sat 11-Aug-07 03:29 by khuie
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Springland uptime is 26 minutes
System returned to ROM by reload at 21:42:29 PCTime Thu Aug 12 2010
System image file is "flash:c850-advsecurityk9-mz.124-4.T8.bin"
Cisco 851W (MPC8272) processor (revision 0x200) with 59392K/6144K bytes of memory.
Processor board ID FHK120921UH
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
1 802.11 Radio
128K bytes of non-volatile configuration memory.
20480K bytes of processor board System flash (Intel Strataflash)
Springland#
SDM Express on the router….
v2.4
bwilks
You can upgrade without SDM via tftp, ftp etc...
copy tftp flash
Address or name of remote host []? 192.168.41.10
Source filename []? c850-advsecurityk9-mz.124-4.T8.bin
Destination filename [c850-advsecurityk9-mz.124-4.T8.bin]?
Accessing tftp://192.168.41.11/c850-advsecurityk9-mz.124-4.T8.bin...
If you want to fix SDM you might like to check your java version. It won't work with newer versions.
http://www.dslreports.com/forum/r21957676-Cisco-SDM-doesnt-launch-SDM-GUI-from-popup-window
