Cisco Terminal server
minumathur
I want to build up cisco 3800 series router as terminal server , i have Asycs 32A module in cisco 3825. Here is show version of device.
question : Do i need to installed any specific IOS in Cisco 3825 device ? how to configure cisco 3825 as terminal server. Thanks you
Cisco 3825 (revision 1.2) with 489471K/34816K bytes of memory.
Processor board ID FTX1508A0TE
2 Gigabit Ethernet interfaces
32 terminal lines
DRAM configuration is 64 bits wide with parity enabled.
447K bytes of NVRAM.
126976K bytes of ATA System CompactFlash (Read/Write)
-Minu
sean_evershed
Level 7
Level 7
You don't need a specific IOS for this. See below a configuration guide
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
