Cisco to Firewall Problem
unleashed333
Dear All
Image is Attached.
Access Switch 2960 --->Core Switch 3750----> SonicWall 4500----->ACCESS Switch(vlan 1)
Access  switch with vlan 90 is directly connected to gig0/12 (routed port of  3750) and FA0 of 3750 is connected to Firewall X3(192.168.80.1) and  Firewall is connected to two others switch with default vlan 1.
3750 is able to ping vlan 1 ip (192.168.1.X)
3750 has static route to vlan 1
3750 is able to ping 192.168.90.X (vlan 90)
firewall is able to ping vlan 1 ip
firewall is able to ping 3750
firewall is unable to ping vlan 90 .
Firewall has route to 192.168.90.X network.
Access switch is unable to ping firewall IP and VLAN 1 (192.168.1.X)
Please find the attached image and let me know where i am lacking.
7 Replies 7
Jan Rolny
Level 3
Level 3
seems that firewall do not know 192.168.90.x network.
Has your Access switch on VLAN90 defined default route to 3750?
Can you post sh ip route of  3750 and 2960 switches?
Also in your post is probably typo, so I want jut to verify if it is correct. You say that one interface is gig0/12 and second is FA0 on 3750 switch? Why FA0?
Best Regards,
Jan
It was mistaknely typed FA0
Output of 3750
Gateway of last resort is not set
S    192.168.1.0/24 [1/0] via 192.168.80.1
C    192.168.80.0/24 is directly connected, FastEthernet0/1
C    192.168.90.0/24 is directly connected, FastEthernet0/0
Firewall route
- Source = Any
- Under Destination = specify Create New Address Object.
    Enter a name for the static route.
    Specify the Zone Assignment as LAN.
    Specify the Type as Network.
    Specify the IP Address 192.168.90.0.
    Specify the Netmask 255.255.255.0
    Click OK.
- Service = Any
- Under Gateway = specify Create New Address Object.
    Enter a name for the local router.
    Specify the Type as Host.
    Specify the IP Address 192.168.80.2
    Click OK.
- Specify the interface as LAN.
- Specify the metric as 1.
Dear All
I made some changes
attached is the Config  of 3750
3750-SWITCH(config)#do sh run
Building configuration...
Current configuration : 1625 bytes
! Last configuration change at 00:37:29 UTC Mon Mar 1 1993
version 12.2
no service pad
hostname 3750-SWITCH
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750x-12s
system mtu routing 1500
ip routing
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
ip address 192.168.80.2 255.255.255.0
no ip route-cache cef
no ip route-cache
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
switchport mode trunk
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
ip address 192.168.90.1 255.255.255.0
ip helper-address 192.168.80.1
ip default-gateway 192.168.80.1
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.80.1
ip route 192.168.80.0 255.255.255.0 FastEthernet0
logging esm config
line con 0
exec-timeout 0 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
end
S*    0.0.0.0/0 [1/0] via 192.168.80.1
      192.168.80.0/24 is variably subnetted, 2 subnets, 2 masks
L        192.168.80.2/32 is directly connected, FastEthernet0
      192.168.90.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.90.0/24 is directly connected, Vlan1
L        192.168.90.1/32 is directly connected, Vlan1
config of 2960
2960-ACCESS#show run
Current configuration : 2420 bytes
version 12.2
no service pad
hostname 2960-ACCESS
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960s-48lps-l
no ip address
shutdown
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
ip address 192.168.90.3 255.255.255.0
ip default-gateway 192.168.90.1
ip http server
line con 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
end
version 12.2
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
no ip address
shutdown
interface Vlan1
ip http server
line con 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
end
Abzal
Level 7
Level 7
1. Check if PC connected port on switch on VLAN 90.
2. Check if PC has default GW as IP 192.168.90.1
3. Configure on access switch in VLAN 90
and on second access switch:
ip default-gateway 192.168.1.1
And how did you test this "firewall unable to ping VLAN 90"?
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Dear Abzal
PC is pinging 192.168.90.1(gateway) and 192.168.80.2(3750X IP) but not 192.168.80.1(firewall IP),
under system/disgnostic there is ping option in firewall .firewall is pinging 192.168.80.2 but not VLAN 90(192.168.90.X)
what about acess list applied on FW? Probably your firewall deny ping from outside by default.
Are you able list route table from FW?
Jan
Dear All
I made some changes
version 12.2
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
ip routing
no ip route-cache
interface Vlan1
ip http server
logging esm config
line con 0
exec-timeout 0 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
end
config of 2960
version 12.2
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
no ip address
shutdown
interface Vlan1
ip http server
line con 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
end
version 12.2
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
no ip address
shutdown
interface Vlan1
ip http server
line con 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
end
