ADSL for HTTP & BGP dual-home on single ISP for SMTP
cinmar1957
I have 1 ADSL for HTTP and 2 Lease Line for SMTP on the same ISP.
I want to achieve HTTP traffic to be on ADSL while smtp traffic to the lease line. (BGP configuration on 2 lease line).
Please help on my current configuration.
interface Loopback0
description LOOPBACK INTERFACE FOR ROUTES
no ip address
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description ADSL
no ip address
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 10
interface GigabitEthernet0/1
description MAIN_LEASELINE
ip address 12.12.12.1 255.255.255.252
ip access-group 110 in
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/0/0
no ip address
interface GigabitEthernet0/0/1
switchport access vlan 2
no ip address
interface GigabitEthernet0/0/2
switchport access vlan 3
no ip address
interface GigabitEthernet0/0/3
switchport access vlan 4
no ip address
interface Vlan1
description VLAN PRIVATE NETWORK
ip address 192.168.5.1 255.255.255.0
ip nat inside
ip policy route-map FOR_SMTP
interface Vlan2
description BACK_UP_PUBLIC
ip address 2.2.2.105 255.255.255.248
interface Vlan3
description BACKUP_LEALSE_LINE
ip address 21.21.21.1  255.255.255.252
ip access-group 111 in
ip nat outside
interface Vlan4
description MAIN_PUBLIC
ip address 1.1.1.193 255.255.255.248
interface Dialer1
ip address negotiated
ip nat outside
ip virtual-reassembly in max-fragments 64 max-reassemblies 512
encapsulation ppp
dialer pool 10
ppp authentication pap callin
ppp pap sent-username XXXX password 7 XXXX
ppp ipcp dns request accept
ppp ipcp route default
ppp ipcp address accept
router bgp 65204
bgp log-neighbor-changes
network 1.1.1.192 mask 255.255.255.248
network 2.2.2.104 mask 255.255.255.248
neighbor 12.12.12.2 remote-as 5384
neighbor 21.21.21.2 remote-as 5384
maximum-paths 2
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static udp 192.168.5.55 3389 interface Vlan4 3389
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 1.1.1.192 255.255.255.248 Loopback0 10
ip route 2.2.2.104 255.255.255.248 Loopback0 10
access-list 1 permit any
access-list 101 permit tcp host 1.1.1.198 any eq smtp
access-list 101 permit tcp host 1.1.1.198 eq smtp any
access-list 101 permit esp any any
access-list 101 permit tcp any host 1.1.1.194 eq 3389
access-list 101 permit udp any host 1.1.1.194 eq 3389
access-list 101 deny   ip host 0.0.0.0 any
access-list 101 permit ahp any any
access-list 101 permit udp any any eq isakmp
access-list 101 permit udp any any eq non500-isakmp
access-list 101 permit udp any any eq biff
access-list 110 deny   tcp any host 12.12.12.1 eq echo
access-list 110 deny   tcp any host 12.12.12.1 eq telnet
access-list 110 deny   tcp any host 12.12.12.1 eq finger
access-list 110 deny   icmp any any redirect
access-list 110 deny   ip host 0.0.0.0 any
access-list 110 deny   udp any any eq snmp
access-list 110 permit ip any any
access-list 111 deny   tcp any host 21.21.21.1 eq echo
access-list 111 deny   tcp any host 21.21.21.1 eq telnet
access-list 111 deny   tcp any host 21.21.21.1 eq finger
access-list 111 deny   icmp any any redirect
access-list 111 deny   ip host 0.0.0.0 any
access-list 111 deny   udp any any eq snmp
access-list 111 permit ip any any
route-map FOR_SMTP permit 10
match ip address 101
set ip next-hop 12.12.12.1
set ip next-hop recursive 21.21.21.1
end
Giuseppe Larosa
Hello Cinmar1957,
if you want to divert SMTP traffic you should match on it
where is SMTP in the ACL?
Hope to help
Giuseppe
Hello Giuseppe,
Thank you for the reply.
This is the ACL on the running-config:
access-list 101 permit tcp any any eq smtp
I think I have a problem also about the routing. If the ADSL link goest down, it will not change to LeaseLine Gateway when I show route.
Cinmar
