cisco unified communications manager virtual machine SIP trunk up/down status monitoring
harinder.rana
Hi Experts,
I want to monitor the cisco SIP trunk up/down status through MIB "ccmStatus". However when i am polling below OID it is showing no MIB response from Cisco UCM. Can you please help how we get the either oid response or SIP up/down status with our monitoring tool.
Cisco UC Virtual Machine      Linux release:2.6.32-431.3.1.el6.x86_64 machine:x86_64
http://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=ccmStatus&translate=Translate&submitValue=SUBMIT
Specific Object Information
Object ccmStatus
OID 1.3.6.1.4.1.9.9.156.1.1.2.1.5
Type INTEGER
Permission read-only
Status current
Values 1 : unknown
2 : up
3 : down
MIB CISCO-CCM-MIB ;   -   View Supporting Images
Description "The current status of the CallManager. A CallManager
is up if the SNMP Agent received a system up event
from the local CUCM
unknown: Current status of the CallManager is
Unknown
up: CallManager is running & is able to
communicate with other CallManagers
down: CallManager is down or the Agent is
unable to communicate with the local
CallManager."
0 Replies 0
