Internal Sub_Net !!!!!!!!!!
j_j624001
Hey Guys;
I need some help here; two of my sub nets are not working; To make a long story short; I'm unable to ping my secondary or third network to my vlan switch which is causing my servers unable to communicate thru my internal network. See info below
On my switch I have created vlan interfaces and vlan's
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  unassigned      YES NVRAM  up                    down
Vlan10                 10.10.0.x       YES NVRAM  up                    up
Vlan15                 10.10.15.x      YES NVRAM  up                    up
Vlan20                 10.10.20.x      YES NVRAM  up                    up
I can ping vlan 10; but unable to ping vlan 15, 20 to the router and/or vice versa router can't ping back to switch on vlan 15, 20.
Interface FA
I even clear my configurations and was still unable to ping back & forth
interface FastEthernet0/2
 description Win-Server
 switchport access vlan 15
 switchport mode access
 switchport nonegotiate
 switchport port-security
 switchport port-security violation protect
 switchport port-security mac-address sticky
 switchport port-security aging static
 speed 100
 duplex full
 arp snap
 spanning-tree bpdufilter disable
 spanning-tree bpduguard disable
If you have any question's or concerns please let me know;
Hello j_J624001,
to what port of the switch is the R1 fastethernet1 connected?
It should be gi0/1 of the switch the only one configured for trunk mode.
Your ping attempts are started from the router or from a host in one vlan ?
The port security configuration on the link between the switch and the router can be removed?
You have the line
switchport port-security mac-address sticky 001e.7aa1.8ca7 vlan 10
but nothing about vlan15 and vlan20 where likely the same MAC address should appear (if it is the R1 fas1 MAC address all subifs use the same MAC address).
I would make a try without port security configured on the switch side of the port to the router.
Hope to help
Giuseppe
6 Replies 6
johnd2310
Level 8
Level 8
Have you enabled routing on the switch? ip routing command
John
**Please rate posts you find helpful**
Hey John;
No I don't believe I don't have that enable due to my setup was working before until I change routers; but here's my config on my switch helpful that would help.
Current configuration : 9182 bytes
no aaa new-model
clock timezone EAST 23 59
system mtu routing 1998
ip subnet-zero
ip port-map dns port 53
ip port-map smtp port 161
ip port-map pop2 port 109
ip port-map pop3 port 110
ip port-map nntp port 119
ip port-map ldap port 389
ip port-map imap port 143
ip port-map nfs port 944
ip device tracking
spanning-tree mode pvst
spanning-tree loopguard default
spanning-tree logging
spanning-tree vlan 1 hello-time 10
spanning-tree vlan 1 forward-time 30
vlan internal allocation policy ascending
interface FastEthernet0/1
 description L-Server
 speed 100
 duplex full
 arp snap
interface FastEthernet0/5
 description client
 switchport access vlan 10
 speed 100
 duplex full
 arp snap
interface GigabitEthernet0/1
 description Sw-FA0/1
 switchport trunk allowed vlan 10,15,20
 switchport mode trunk
 speed 100
 duplex full
 arp snap
interface Vlan10
 ip address 10.10.0.x 255.255.255.0
 ip broadcast-address 255.255.255.0
 ip mask-reply
 ip information-reply
 ip sticky-arp
 no ip route-cache
 ip tcp adjust-mss 1460
 arp snap
 spanning-tree portfast
interface Vlan15
 ip address 10.10.15.x 255.255.255.0
 ip mask-reply
 ip sticky-arp
 no ip route-cache
 arp snap
interface Vlan20
 ip address 10.10.20.x 255.255.255.0
 ip mask-reply
 ip sticky-arp
 no ip route-cache
 arp snap
no ip http server
access-list 40 permit 10.10.x.x 0.0.255.255
Hello j_j624001,
the router should be connected to the following interface:
 speed 100
 duplex full
 arp snap
and should have Vlan subinterface for each Vlan
router config:
int gi0/0
no ip address
int gi0/0.10
encapsulation dot1q 10
ip address 10.10.0.y 255.255.255.0
int gi0/0.15
enc dot1q 15
ip address 10.10.15.y 255.255.255.0
int gi0/0.20
enc dot1q 20
ip address 10.10.20.y 255.255.255.0
in this way the router will provide the intervlan routing
Otherwise you need to enable inter vlan routing on the switch
Hope to help
Giuseppe
Hello; I have Vlan subinterfaces on my router; so it must be on my switch; idk; here configuration on router and switch; on my switch I have three vlan's im using for internal from show vlan brief.... Idk see configurations
Router
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.0.1 10.10.0.84
ip dhcp excluded-address 10.10.0.101 10.10.0.255
ip dhcp excluded-address 10.10.20.1 10.10.20.84
ip dhcp excluded-address 10.10.20.101 10.10.20.255
ip dhcp pool 10_Net_POOL
   import all
   network 10.10.0.0 255.255.255.0
   update dns
   default-router 10.10.0.1
   dns-server 10.10.15.2 10.10.15.3 8.8.8.8 8.8.4.4
   domain-name J_Internal_Net.com
   update arp
ip dhcp pool 20_NET_POOL
   import all
   network 10.10.20.0 255.255.255.0
   update dns
   default-router 10.10.20.1
   domain-name BACK_NET.com
   update arp
ip ssh version 2
 description OUT
 ip address 192.168.0.x 255.255.255.0
 ip access-group filter-inbond in
 ip access-group filter-outbond out
 ip nat outside
 ip virtual-reassembly
 speed 100
 full-duplex
interface FastEthernet1
 description Internal
 no ip address
 ip nat inside
 speed 100
 full-duplex
interface FastEthernet1.10
 description Clients
 encapsulation dot1Q 10
 ip address 10.10.0.1 255.255.255.0
 ip nat inside
 no snmp trap link-status
interface FastEthernet1.15
 description Servers
 encapsulation dot1Q 15
 ip address 10.10.15.1 255.255.255.0
 ip nat inside
interface FastEthernet1.20
 description Backup
 encapsulation dot1Q 20
 ip address 10.10.20.1 255.255.255.0
 ip nat inside
ip route 0.0.0.0 0.0.0.0 192.168.0.x
no ip http server
no ip http secure-server
ip nat inside source list 50 interface FastEthernet0 overload
ip access-list extended filter-inbond
 permit icmp any any echo-reply
 permit tcp any eq www any established
 permit tcp any eq 443 any established
 permit tcp any eq 8080 any established
 permit udp any eq domain any
 deny   ip any any
 deny   udp any any
 deny   tcp any any
ip access-list extended filter-outbond
 permit udp any any eq domain
 permit tcp any any eq www
 permit tcp any any eq 443
 permit tcp any any eq 8080
 deny   ip any any
 deny   tcp any any
 deny   udp any any
access-list 50 permit 10.10.0.0 0.0.255.255
control-plane
Switch
Current configuration : 9271 bytes
version 12.2
no service pad
hostname SW1
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip domain-name J10.Net.com
ip name-server 255.255.255.0
ip device tracking
 speed 100
 duplex full
 arp snap
interface FastEthernet0/6
 description client
 speed 100
 duplex full
 arp snap
 speed 100
 duplex full
 arp snap
interface GigabitEthernet0/2
 description AP
 speed 1000
 duplex full
 arp snap
interface Vlan1
 no ip address
 no ip route-cache
interface Vlan10
 ip address 10.10.0.2 255.255.255.0
 ip helper-address 10.10.0.1
 ip mask-reply
 ip sticky-arp
 no ip route-cache
 arp snap
interface Vlan15
 ip address 10.10.15.2 255.255.255.0
 ip helper-address 10.10.15.1
 ip mask-reply
 ip sticky-arp
 no ip route-cache
 arp snap
interface Vlan20
 ip address 10.10.20.2 255.255.255.0
 ip helper-address 10.10.20.1
 ip mask-reply
 ip sticky-arp
 no ip route-cache
 arp snap
no ip http server
access-list 40 permit 10.10.0.0 0.0.255.255
Hello j_J624001,
You have the line
Hope to help
Giuseppe
Hello Giuseppe;
my router is connected to switch port Gi0/1 which is trunk to allowed other vlans to commiuncate.
I got it now; after removing the switchport security; I was able to ping all vlans from router-switch-client or vice versa;
